While performing work on an internal pseudo-wire table entry, the control block data used to manage the entry could not be found.
Since the control block data was missing, the action being performed on the pseudo-wire likely did not complete. Disabling and enabling the L2VPN or CES container for the pseudo-wire may restore normal operation. To enable/disable an L2VPN, use the "enable/disable l2vpn" command. To enable/disable a CES, use the "enable/disable ces" command. If the problem continues, disabling and enabling MPLS will cause this internal table to be reset. To enable/disable MPLS, use the "enable/disable mpls" command.
Error
Control block data for the pseudo-wire with index %pwIndex% was not found %action%
| Name | Type |
| pwIndex | uInt32 |
| action | Printf |
